2005 Toyota Camry Sounds like something rolling around in e
2005 TOYOTA CAMRY
72,499 MILES • 4 CYL • 2WD • AUTOMATIC
THORG19
When turning or going forward from a stopped position, a noise in the front end occurs. It sounds like something rolling around, but I don't find anything loose. It appears to be getting worse, and now I hear it when start the engine. I've tried turning everything off to see if it might be related to the AC or some other device, however it does it regardless.
Aug 20, 2010 at 4:00 AM
MERLIN2021
  • 17,250 POSTS
Check you engine and transaxle mounts.
Aug 20, 2010 at 4:01 AM
