2005 Toyota Camry Maintainace Required flasing for six-time
45,000 MILES • 4 CYL • 2WD • AUTOMATIC
VENKATAGUPTA
Whenever I start my engine, the Maint Reqd is flashing for exactly six times and then going off.. This is happenning continously and consistantly for past 2 weeks..
Please help
Thanks
Venkat
Mar 7, 2008 at 2:30 AM
SERVICE WRITER
  • 9,123 POSTS
Was the oil change done?
The light will flash if the light was not reset at the time of the change.
to reset:
1-put the key in the acc position with the odometer showing.
2-turn the key to the on position. hold the trip meter reset button until the odometer shows "000000", takes about 5 seconds.
Mar 7, 2008 at 2:52 AM
VENKATAGUPTA
thanks for the suggestion. I did the oil change only one month back. But at that time, the mechanic said that I need to change the Power Steering Fluid. Is this the reason for the flashing
Thanks
Venkat
Mar 9, 2008 at 5:52 AM
SERVICE WRITER
  • 9,123 POSTS
Did you do the reset that I just wrote. The light needs to be reset.
What does your power steering fluid look like?
An no that isn't the reason.
Mar 9, 2008 at 8:31 AM
VENKATAGUPTA
Thanks for the solution and it worked.. I didn't done it properly for the first time. Actually what I did now is
hold the trip meter reset meter button and turn the key to the on position until the odometer shows "000000", and it take less 5 seconds.
Thanks again for the timely help..
Mar 10, 2008 at 6:05 AM
