2005 Toyota Camry low idling
2005 TOYOTA CAMRY
73,500 MILES • 4 CYL • FWD • AUTOMATIC
BRAD5050
I changed my serpentine belt today and after putting everything back together and starting the car, it started fine and idled normal(800-1000rpm), then after a few seconds of running the rpm's dropped to about 200-400rpm for a few seconds then went back to normal for about 30-45 seconds, then repeatedly did this over and over. I drove the car to the store and when braking for lights and corners it almost stalls, the lights go dim inside and out?
Nov 16, 2008 at 12:18 PM
ZACKMAN
  • 4,202 POSTS
Check the belt tension. It is probably too loose.
Nov 16, 2008 at 6:20 PM
