2005 Toyota Camry car won't idle after refueling
2005 TOYOTA CAMRY
120,000 MILES • 4 CYL • FWD • AUTOMATIC
MANDERSCHEIT
my wifes car won't stay idling after you refuel. It happens every time you fill the tank and only when you refill the tank. She has to run the rpms' up manually for about a minute before it will set the idle. Then everything is normal until you refill the tank again.
thank you
Oct 7, 2010 at 12:50 PM
KHLOW2008
  • 41,814 POSTS
Hi manderscheit,
Is the Check Engine Lamp indicating?
Oct 8, 2010 at 5:20 AM
