2005 Toyota Camry Car Dead
102,000 MILES • 4 CYL • 2WD • AUTOMATIC
NAVY1984
Our Toyota wouldn't start, today. When my wife went to go to work, her remote access wouldn't work. She didn't think too much about it and unlocked the car with her key. When she tried to start it, she found that she has no power to ANYTHING. I have had the battery tested and it checks out fine. The auto parts store that I went to, said it is probably the starter relay, which made sense. I bought a new one and replaced it, and still nothing. When you put the keys into the ignition, and turn the key as to start the car, all of the dash board lights turn on for about 2 seconds then nothing. I really need help.
Jul 6, 2010 at 11:26 AM
  • 75,988 POSTS
No crank at all/nothing/nada:
Could be a blown fusible link,the starter,starter relay, park and neutral switch/transmission position switch and ignition switch assuming the battery and connections are good. Note:If it doesn't apply disregard.
Jul 6, 2010 at 11:30 AM
FORDRACING24
  • 65 POSTS
If the battery is dead in the key fob the car won't start. This happened to me at work today.
Jul 6, 2010 at 1:35 PM
