2005 Toyota Camry battery leakage
2005 TOYOTA CAMRY
75,000 MILES • 6 CYL • FWD • AUTOMATIC
GUDRA78
my battery have acid leakage i try to fix it to clean with a brush and i put a spray for battery corrosion but it keeps coming back and now i deicide to replace the battery and to put the brand nwe one is that a goog idea please answer me thanks Marc
Sep 14, 2008 at 11:45 AM
  • 31,937 POSTS
Hi there,
I would be getting the alternator checked for over charging as your battery bay be boiling causing the acid spill, you can clean up the acid with warm water and bi-carb soda solution this will neutralize the acid then flush with clean water.
Mark (mhpautos)
Sep 14, 2008 at 11:56 AM
