2004 Toyota Camry WOBBLE NOISE
110,000 MILES • 4 CYL • 2WD • AUTOMATIC
JIJOHNS2
just had front end struts replaced. Only in early morning and cool-humid mornings the car has a wobble, hollow noise for the first few miles. Goes away when it warms up until the next humid morning. I can lift up over the wheel well/fender and hear the same noise. (similar to a dried out rubber piston in a tube) until it heats up. Can moisture affect a new strut? could have the new strut obtained moisture/rust or pitting around the internal rubber piston?
Oct 15, 2010 at 9:00 AM
MMPRINCE4000
  • 8,548 POSTS
Take back to installer and have them fix it.
If you are saying the car is wobbling, then something is not tight.
Oct 16, 2010 at 12:44 AM
