2004 Toyota Camry TUNE UP
51,000 MILES • 4 CYL • 2WD • AUTOMATIC
NAWROZED
I had my first tune up at 35000 miles now the car has 51000 miles on it when should i get a tune up done?
Oct 22, 2009 at 3:43 PM
JOE C.
  • 25 POSTS
In my opinion, no you shouldn't. I don't believe that you needed one at 35,000. Ask your dealer, but I think the plugs are probably good for 90,000 miles. The plug wires should be good for that if not more. Original equipment Toyota wires are excellent quality. Check air filter, replace if dirty. If it has a PCV valve easily accessible in the top of the valve cover, it can be checked easily, and I doubt its plugged. I'm not a mechanic, but I work on our Camrys except for the timing belt, and I have 334,000 miles on a 1999. I hope you like your 2004, I rode in one the other day, it is a very nice car. Hope that helps.
Oct 22, 2009 at 7:09 PM
