2004 Toyota Camry Speed Pickup
NOORULHAQUE
  • 2004 TOYOTA CAMRY
  • 6 CYL
  • MANUAL
  • 170,000 MILES
How can I improve my cars pickup(speed), as its seems slow in first gear.
Sunday, August 15th, 2010 AT 6:40 PM
Lack of acceleration, chugging, hesitating, bogging, misfiring etc. Could be caused by one of the following below:
Start here-I know it's alot but please inspect and test all the items below to fix your problem:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Sunday, August 15th, 2010 AT 6:58 PM
Related General Content
