2004 Toyota Camry MUFFLER
STEVAN KOSTIC
2004 Toyota Camry 4 cyl Front Wheel Drive Automatic
HOW TO FIX AHOLE ON THE MUFFLER
Oct 3, 2010 at 1:33 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Locate the hole in your exhaust system. If it is not readily visible turn the car on and try looking for the vapor escaping or tracing the louder noise.
Purchase a muffler hole repair kit at your local automotive store.
Turn off the car and jack it up if necessary to reach the hole.
Wrap the muffler tape around the muffler or hole completely and cover the hole totally with several layers of the tape. The tape is self adhesive usually or is activated by the mufflers heat and will keep itself on securely.
Oct 3, 2010 at 1:38 PM
