I noticed a gurgling sound coming from under the steering column right after the car is started and the engine is cold. There are no leaks inside or outside. Coolant and oil levels are fine.
I took it to the dealer and they say there is a leak in the water pump and its sucking air in. I'm skeptical of that explanation.
I'm hoping someone can help.
Thanks,
Pakisam
Thanks,
Pakisam
Dec 29, 2008 at 11:13 AM
