2004 Toyota Camry fog light kit
DBIDDERDAVE
2004 Toyota Camry 4 cyl Front Wheel Drive Automatic
i need instructions, preferably with some photos on how to install a fog light kit on a 2004 toyota camry.
Oct 19, 2009 at 3:47 AM
RACEFAN966
  • 5,029 POSTS
Ok what kind of fog light kit? Is it a factory or aftermarket set? Get back to me and I will try to help from there.
Oct 20, 2009 at 3:24 AM
DBIDDERDAVE
[quote:28af0c0042="racefan966"]Ok what kind of fog light kit? Is it a factory or aftermarket set? Get back to me and I will try to help from there.[/quote:28af0c0042]
It's an aftermarket kit with wiring harness,relay,fuse and various plugs.
Oct 20, 2009 at 4:01 AM
DBIDDERDAVE
it's a aftermarket kit with wiring harness,relay,fuse and various plugs.
Oct 20, 2009 at 4:31 AM
RACEFAN966
  • 5,029 POSTS
Ok so are there any instructions in the kit? If not what brand of kit is it? I need to know so I can try to find a wiring diagram for you so I can help you with the relay hookup and such.
As for the most of it you will need to figure out where to install the lights and where you want to install the switch. Get back to me with the brand of the lights and I will try to find a wiring diagram for you from there.
Oct 21, 2009 at 3:20 AM
DBIDDERDAVE
[quote:00715a0884="racefan966"]Ok so are there any instructions in the kit? If not what brand of kit is it? I need to know so I can try to find a wiring diagram for you so I can help you with the relay hookup and such.
As for the most of it you will need to figure out where to install the lights and where you want to install the switch. Get back to me with the brand of the lights and I will try to find a wiring diagram for you from there.[/quote:00715a0884]
the lights came from watomi racing with no instructions or manufacturer information. nothing was stamped or marked on the housing or wiring harness. everything plugs together except two plugs and two wires with an open stake-on connector.
Oct 23, 2009 at 2:48 AM
RACEFAN966
  • 5,029 POSTS
Ok can you lay it all out and take a pic of it and include it in your next response. I need to know what type of relay and how many and how it connects and so on so I can get a diagram for you from what I see. There is more then one way to hook up aftermarket lights so this will be very helpfull so I can correctly answer your question. Thanks
Oct 23, 2009 at 3:47 AM
