2004 Toyota Camry Engine Sputters
130,000 MILES • 4 CYL • 2WD • AUTOMATIC
DONNA ULI
After a tune-up performed at the dealership, my car began to "sputter" or "jump" and I felt that it was going to kill. What could cause that? Also, by the time I drove to the dealership (45 miles away), the Check Engine light came on.
Jul 30, 2008 at 2:01 AM
KLSHIEL
  • 163 POSTS
Your describing an engine missfire. one or more cylinders are not fireing as should. This could be as simple as a plug wire not on all the way. Or something under the hood got pumped loose. A miss fire could be what set the light.
Jul 30, 2008 at 2:29 AM
DONNA ULI
Thanks. Appreciate the quick response.
Jul 30, 2008 at 2:40 AM
KLSHIEL
  • 163 POSTS
Also if it is either of these two things the shop that did the tune up should fix it for free of charge
Jul 30, 2008 at 3:26 AM
