2004 Toyota Camry Engine cold start problem
74,000 MILES • 4 CYL • FWD • AUTOMATIC
DANNYFU
Hi 2carpros,
i experienced an engine cold start problem with my camry early in the morning or after parking the car for more than an hour. The engine would rev up to 2000rpm n drop down to 1000rpm then up and down again upon start up, then the car would start to vibrate as if it is experiencing a mis-fire. And the Battery light comes on for about 1min before going off when the engine rpm stabilised.
i had recently sent my car for bonnet replacement and the problem arises after the bonnet change. i had changed my car battery 2 mths ago
What is the likely cause of this problem, pls advice
Thanks
Danny
May 14, 2008 at 1:04 AM
  • 75,988 POSTS
Do you have a check engine light?
Get the charging system, idle air control valve and throttle position sensor checked out-
May 14, 2008 at 1:22 AM
