2004 Toyota Camry door locks
WOLDEL
  • 2004 TOYOTA CAMRY
Electrical problem
2004 Toyota Camry 4 cyl Two Wheel Drive Automatic
door locks only unlock drivers door, remote only unlocks drivers dooor. Pass door switch will unlock alll but not lock.
reprogrammed remote and car still no luck. Changed out master switch ( drivers side door switch) still no luck
Saturday, August 21st, 2010 AT 12:53 PM
  • 109,885 POSTS
This sounds like a relay issue. Have you checked them?
Monday, August 12th, 2019 AT 5:48 PM
WOLDEL
  • 12 POSTS
Where are the locations for the relays other than the one under the hood that one is fine.
What about the body control module?
  • 109,885 POSTS
I believe the BCM is behind the driver's side kick panel. As far as the relays, I believe the only ones are in the power distribution center.
