2004 Toyota Camry computer failure
123,000 MILES • 4 CYL • FWD • AUTOMATIC
MALONEP
I just sent my 04 Camry into the dealership for various mechanical work. They called me and diagnosed an 02 sensor problem and a bad catalytic converter. Several hours later, they called back and said that while they were doing further diagnosis, my on board computer suddenly "died" and it would cost me over $1,400.00 to replace. The car was running fine when it got there, now they tell me it won't even start. Am I being ripped off?
Thanks
Dec 18, 2009 at 10:41 PM
  • 31,937 POSTS
Hi there,
Replacing a cat and fitting a new 02 sensor will not damage a ECU, if the battery was off and this caused a spike in voltage or the cat was welded, this can also cause a voltage spike that can cause this problem, the problem you will have is proving that they did this.
Mark (mhpautos)
Dec 18, 2009 at 11:10 PM
