2004 Toyota Camry Car shakes badly when going up on hills.
64,000 MILES • 6 CYL • 2WD • AUTOMATIC
ARSENELPK
My car shake badly when its on load. like going up on hills bridges etc.. Can it be engine misfire? I have showed it to dealer as well and they were unable to find the cause.
Jul 16, 2010 at 7:58 AM
  • 75,988 POSTS
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Jul 16, 2010 at 9:10 AM
