2004 Toyota Camry Car Feels Different
155,000 MILES • 4 CYL • FWD • AUTOMATIC
SUPERLEGGERA
hello, im experiancing problems with my car, it feels less powerful and the engine sounds more muffled. it used to be a lot louder. It also feels as if the brakes are engaged while im driving because when i take my foot off the accelerator the RPM's drop very fast.
Sep 9, 2010 at 9:16 AM
  • 75,988 POSTS
Lack of acceleration, chugging, hesitating, jerking, bogging, misfiring etc. could be caused by one of the following below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Sep 9, 2010 at 9:20 AM
