2004 Toyota Camry '04 Camry Rotor removal
65,000 MILES • 6 CYL • FWD • AUTOMATIC
REB5795
I have the calipers off. Appears on the center of the rotor there is a bolt cover/shield. Does this need to be removed to take the rotors off? I can't tell if that is the issue in removal, or they are just rusted on.l
this is a camry-solara convertable - not sure if that makes a difference
Nov 7, 2009 at 4:18 AM
STEVEW84
  • 673 POSTS
IF you are not reusing the rotor then you need to take a dead blow or a big hammer to the face of the rotor to get it off.
Nov 7, 2009 at 5:08 AM
