2003 Toyota Camry wont go in gear
30,000 MILES • 4 CYL • FWD • AUTOMATIC
DALVAH
the button on the gear shift wont go in so i can put my car in gear
Mar 29, 2010 at 2:39 PM
COLIND1216
This probably means that the transmission locked up. If you look in the manual, it should tell you how to override it. There should be a small flip-up compartment next to the "park" gear that you can loosen with a screwdriver and inside is (I guess a button or something) that will unlock the gears so you can shift out of "park".
Apr 12, 2010 at 6:12 AM
