2003 Toyota Camry TURN SIGNAL VOLUME
2003 TOYOTA CAMRY
36,000 MILES • 4 CYL • 2WD • AUTOMATIC
FORLANIAL
The sound volume that my turn signals emit is so low that many times it stays on after a less than 90 degree turn. I there any way I can modify the volume from the flasher unit? I have a 2003 toyota 4 cly. camry.
Thans for any help you can provide.
Al Forlani
forlanial@yahoo.com
Jan 15, 2008 at 5:53 AM
  • 31,937 POSTS
Hi there,
I would fit a new flasher control unit(flasher can) The self cancel of the indicators is controlled by the indicator switch and the base of the steering wheel, you can't adjust this procedure.
Mark (mhpautos)
Jan 15, 2008 at 8:15 AM
