2003 Toyota Camry TUNE UP
2003 TOYOTA CAMRY
78,000 MILES • 4 CYL • FWD • MANUAL
ZMOHTADI
MY CAR SUDDENLY LOST THE RPM I PUT PAPER BORD BELOW THE GAS PADELL TO RAISE THE RPM SO IT WILL NOT DIE ON ME I THINK I NEED TUN UP IT ALL HAPPENED WHEN I CHANGED THE BATTERY THE PROBLEM IS WHERE IS THE SPARK PLUGS LOCATED I OPENED THE ENGINE TOP COVER ALL I CAN SEE IS NO SPARK PLUGS PLEASE HELP.
Aug 17, 2009 at 3:38 PM
When you disconnect the battery you caused the computer to lose some memories its probably going thru a computer relearning process.
Aug 17, 2009 at 5:17 PM
