2003 Toyota Camry torque on head
10,000 MILES • 4 CYL • FWD • AUTOMATIC
DK4236
The shop doing the head work on my Camry, said 70 75 80? Foot pounds of torque on the head. The problem is four of the bolt casings polled out of the block. I called a dealer they said 58 f/p/t on bolts. Is there an additional 90 degree turn after 85 f/p/t has been reached?
By the way, they quoted me 2,500 to 3,000 for work.
Blown head gasket, machined head, reset valves, new timing belt. (?)
With a new top end on, will this make the bottom end week?
100,000 miles on this car.
Thank you for your time.
Darrin.
Jul 29, 2009 at 9:21 AM
  • 31,937 POSTS
Hi there,
I am just checking on these spec for you and will re post soon,
mark (mhpautos)
Jul 29, 2009 at 9:40 AM
  • 31,937 POSTS
Hi there,
the head tension should be 38Ft Lb (47 Nm) then a further 90Deg they have over tensioned the bolts. also new torque to yield bolts must be used, if the bottom end is in poor condition oil consumption may occur due to the increased compression.
Mark (mhpautos)
Jul 29, 2009 at 10:37 AM
