2003 Toyota Camry Tire Wear
72,000 MILES • 4 CYL • FWD • AUTOMATIC
MIKE.WALLS
I'm experiencing slight cupping and feathering on the inside for both front tires. I've had the alignment check three times at two different shops and found no alignment problems. Could this be an indication of suspension or cv joint problem. My problems started some time after a sudden stop from 70mph. I had to replace the tires after some newly acquired flat spots.
Jan 27, 2008 at 11:22 AM
BMRFIXIT
  • 19,053 POSTS
[quote:cd69af809b="mike.walls@thewallsfamily"]Other Category problem
2003 Toyota Camry 4 cyl Front Wheel Drive Automatic 72000 miles
I'm experiencing slight cupping and feathering on the inside for both front tires. I've had the alignment check three times at two different shops and found no alignment problems. Could this be an indication of suspension or cv joint problem. My problems started some time after a sudden stop from 70mph. I had to replace the tires after some newly acquired flat spots.[/quote:cd69af809b]
try to rotate tire more often
specially if you do a lot of city driving
check tire pressure
Jan 27, 2008 at 11:46 AM
