[quote:1d671f43fe="nalynne"]Engine problem
2003 Toyota Camry 4 cyl Two Wheel Drive Automatic 87000 miles
At what milage should a timing belt be changed? Will it damage anything if it breaks and does it operate the water pump?[/quote:1d671f43fe]
60K or 5 years, maybe and yes.
Anytime the belt breaks or strips, the valves could be hit by the pistons, Toyota 4 cylinders has been one that seems to be designed not to hit the valves(if it has a belt).
when you replace the belt, it is best to buy a timing belt kit(a new belt, idler and tensioner) and replace the water pump as well.
Jeff M.
Dec 12, 2007 at 2:40 AM
