2003 Toyota Camry throtle position sensor
122,180 MILES • 4 CYL • FWD • AUTOMATIC
DIMITRI
i replace the battery on car i installed memory saver but i found out later it had dead battery, after the replacement the car wont idle I drove 20 miles still wont idle i need to know how to reprogram the throtle position sensor
Sep 26, 2009 at 4:29 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Computer needs to relearn take up to 5 drive cycles ie. key offf and restart. so go for series of short trips turn off and on till fault clears.
Hope this helps
Thanks for donate
Sep 26, 2009 at 8:05 AM
