2003 Toyota Camry Starter
95,000 MILES • 4 CYL • 2WD • AUTOMATIC
NIDRAC
Engage key, no sound, radio responds as usual, release key radio comes back on, idiot lights do not appear to dim.
Shift gear to neutral the response is the same.
This happened suddenly with no prior difficulties
Mar 2, 2010 at 2:13 AM
  • 75,988 POSTS
No crank at all/nothing/nada: Your possibilities
Could be the starter, starter relay, clutch switch/park and neutral switch and ignition switch assuming the battery and connections are good.
Mar 2, 2010 at 3:18 AM
