2003 Toyota Camry Starter
NIDRAC
  • 2003 TOYOTA CAMRY
  • 4 CYL
  • 95,000 MILES
Engage key, no sound, radio responds as usual, release key radio comes back on, idiot lights do not appear to dim.
Shift gear to neutral the response is the same.
This happened suddenly with no prior difficulties
Tuesday, March 2nd, 2010 AT 10:13 AM
No crank at all/nothing/nada: Your possibilities
Could be the starter, starter relay, clutch switch/park and neutral switch and ignition switch assuming the battery and connections are good.
Tuesday, March 2nd, 2010 AT 11:18 AM
