2003 Toyota Camry scraping noise
78,000 MILES • 4 CYL • FWD • AUTOMATIC
SZCZESNIAK
I have ABS brakes which are a couple years old, and now I hear a scraping noise underneath the car when I brake. Does this usually happen with ABS when they are starting to wear down? With ABS do I still have brake pads/shoes etc....just so I know what to expect to be told from whatever mechanic I go to....
Jul 24, 2008 at 1:41 AM
BMRFIXIT
  • 19,053 POSTS
ABS is an electronic system that monitor the brakes
and prevent lockup and or skidding
this all work with the combination of regular brake
yes you have the same as always pads rotors and all the usual
you should have the brakes checked
Jul 24, 2008 at 2:15 PM
