2003 Toyota Camry Power Windows (Rear)
DKEENER635
Electrical problem
2003 Toyota Camry 4 cyl Wheel Drive Type unknown Automatic 47000 miles
I have a 2003 Toyota Camry and both power rear windows stopped working. The right one stopped first and then the left one. They will not rol down from either the fromt drivers side control module nor will they roll down from the individual rear window controls. I suspect that the rear controls may go through the front driver's side control, but I do not have a wiring diagram so I'm not sure. I thought it was probably the regulator or the motor when the first one went out, but when the second one went out it made me suspicious that it may be electrical related -- maybe even a fuse or a relay.
Thanks for your help.
David
Feb 21, 2008 at 7:31 AM
SATYRIAS
I have the same problem with 2002 Camry rear window on drive side. It stopped working for a while and then came back. Again it is not working now.
Since it has worked once after the first problem, I am assuming it is not the problem with the motor or the regulator. It has something to do with electrical connectivity.
If I go to Toyota dealer, they will tell me to replace the motor to make money for a silly connection problem.
I wonder how to figure out which is the corresponding fuse for this window. There is no diagram to follow it.
Any help
Mar 4, 2008 at 1:23 AM
