2003 Toyota Camry noisey steering column
TOMDEE
Steering problem
2003 Toyota Camry V6 Front Wheel Drive Automatic 60,000 miles
My steering column makes a squeal - as if it is rubbing on the actual column. This squeal is on the column inside the vehicle and not the belt.
Dec 11, 2007 at 4:42 AM
CGBRIDGES1
[quote:72850db2b7="tomdee"]Steering problem
My steering column makes a squeal - as if it is rubbing on the actual column. This squeal is on the column inside the vehicle and not the belt.[/quote:72850db2b7]
I also own a 2003 V6 Camry with the same problem. I have yet to take it to a shop for repair quote. If you have any further info please post.
cgbridges1@hotmail.com
thanks
Jan 12, 2008 at 3:29 AM
