2003 Toyota Camry NOISE WHEN BRAKING
89,000 MILES • 4 CYL • 2WD • AUTOMATIC
SALCIDO21
i have 2003 toyota camry and i replaced the rear and front brakes pads and every time i apply the brakes they make squeaking nosie in the rear and the front feel ruff.
Sep 29, 2009 at 2:49 AM
  • 110,248 POSTS
Were the rotors resurfaced? If not, there is most likely a glaze on them causing this for you.
If this is the case, have the rotors resurfaced and take sand paper to the pads to deglaze them. That should take care of the problem.
Let me know if it helps.
Oct 5, 2009 at 12:36 AM
