2003 Toyota Camry No Heat
125,000 MILES • 4 CYL • FWD • AUTOMATIC
SKIP11
Just noticed that the heater is not working.(at all)
1-A/C is fine
2-No apparent leaks
3-No smell of antifreeze
4-The thermostat gage is working fine
5-Antifreeze level is full when ice cold.
6-Fans and air direction controlls are fine
Oct 1, 2009 at 2:24 AM
  • 110,246 POSTS
With the engine hot and running and the heater on high, feel both heater core hoses. They should be hot.
Let me know what you find.
Oct 5, 2009 at 12:26 AM
SKIP11
Thanks for the reply. I actually found the problem this weekend. Both hoses were hot so i traced the problem to the blend door actuator. I took apart the actuator and cleaned the electodes. Works now, but i will need a new one soon. the electical tracks are worn out. Do you know if they sell a electrical conducting paint?
Oct 5, 2009 at 8:42 AM
  • 110,246 POSTS
If both hoses were hot, that was the next thing I planned to have you check. As far repairing it, I don't know of any such product, but that doesn't mean they don't make it. Maybe a good parts store would know.
Let me know what you find out and thanks for using 2carpros.com.
Oct 5, 2009 at 1:27 PM
HIFIGUY
[quote:b204269607="skip11"]Thanks for the reply. I actually found the problem this weekend. Both hoses were hot so i traced the problem to the blend door actuator. I took apart the actuator and cleaned the electodes. Works now, but i will need a new one soon. the electical tracks are worn out. Do you know if they sell a electrical conducting paint?[/quote:b204269607]
Where is the blend door actuator, and is it easy to inspect?
Nov 1, 2009 at 6:31 PM
