2003 Toyota Camry Girgling noise from transmission
2003 TOYOTA CAMRY
80,000 MILES • 4 CYL • FWD • AUTOMATIC
GENE MALONE
When stopped with the engine running there is a girgling noise coming from the transmission. I was stold it could be air in the transmission. How do you fix it.
Oct 29, 2009 at 7:38 AM
  • 31,937 POSTS
Hi there,
The first thing to do is check the oil level, check it in park with the transmission hot and engine idling, adjust the level if required and post if the oil level is already OK.
Mark (mhpautos)
Oct 29, 2009 at 8:38 AM
