front passenger seat will not go back after it was moved all the way to the front?
2003 TOYOTA CAMRY
SAMMY77
I don't understand why the front passenger seat will not go back after it was moved all the way to the front. The motor clicks when you press the button and it heats up but the seat will not push back. There is nothing hindering the track and I cannot see if it has locked or anything. Any ideas on how to fix it?
Sep 28, 2007 at 6:11 AM
SAMMY77
I tried to push it and see if there was some kind of lock but nothing. The motor is clicking like it wants to move but the shaft is not moving. The motor is also heating up because of the numerous times I am trying to make it move. What's next?
The next step its to pull out the motor and test it out...
(with the same connector.)
in some cases its easiest to unbolt the seat, that way you have more space to work with.
Sep 28, 2007 at 9:28 AM
