2003 Toyota Camry engine whine-reviving engine
2003 TOYOTA CAMRY
60,000 MILES • 4 CYL • 2WD • AUTOMATIC
RICHARDG
Engine makes whing noise after ii is warm,never when cold Had new drive belt put on it.Could it be belt or water pump,doesnt overheat.Sound seems come front of engine?
Dec 23, 2007 at 11:26 AM
SERVICE WRITER
  • 9,123 POSTS
Sounds like a bearing problem of some sort.
You can use a homemade stethsescope to narrow it down. A long screwdriver/pry bar etc will work. Place the tip near each pulley on it's housing and your ear to the handle. Have someone rev it while you listen to each area to find it.
Dec 23, 2007 at 11:30 AM
RICHARDG
Can the new belt cause whine or is it more serious? 2003 Toyota Camry-4cyl. Water pump? --Belt tensioner?
Dec 23, 2007 at 11:32 AM
SERVICE WRITER
  • 9,123 POSTS
[quote:922fa51a96="RichardG"]Can the new belt cause whine or is it more serious? 2003 Toyota Camry-4cyl. Water pump? --Belt tensioner?[/quote:922fa51a96]
Was the noise there prior to replacement?
Belt tensioner wouldn't surprise me. Sometimes they get stiff and don't return all the way giving insufficent tension.
You need to do the test I explained above to narrow it down.
Dec 23, 2007 at 11:40 AM
