2003 Toyota Camry engine air filter and spark plugs
32,000 MILES • 4 CYL • FWD • AUTOMATIC
BILL85
How do I change the engine air filter on a 2003 Toyota? Is it necessary to change spark plugs at 30,000mi? My neighbor says that they will last to 100,000mi.
Nov 11, 2008 at 7:30 AM
  • 31,937 POSTS
Hi there,
The spark plugs are under the 4 rubber boots on top of the engine, don't pull the leads, pull on the boot, if normal spark plugs are fitted the should be replace at 30,000 Km, if iridium or platinum the will be good for the 100,000 Kim's. the air filter is in the large black box undo the clips around the side and lift up, it is a dry paper element.
Mark (mhpautos)
Nov 11, 2008 at 8:40 AM
