2003 Toyota Camry emissions trouble code P0456
2003 TOYOTA CAMRY
60,000 MILES • 4 CYL • FWD • AUTOMATIC
SCOTPIPER
I have a 2003 toyota camry with about 60,000 miles. The check engine light has started going off. My code reader shows code P0456: EVAP emission control system leak (very small). I spoke with toyota service techs and verified that I ALWAYS make sure to click the gas cap at least once after filling. I see there is a fuel filler neck corrosion issue after researching the internet. I checked and do have the corrosion. I used steel wool to remove some and lubed the ring. How do I replace the fuel filler neck myself? I plan to start by replacing the filler cap and see if that takes care of the code.
May 4, 2008 at 7:01 AM
MASTERTECHTIM
  • 4,750 POSTS
is there a lot of pitting? i usually find that this code is caused by a bad vent solenoid located on the charcoal canister.
May 4, 2008 at 7:04 AM
