2003 Toyota Camry Emissions
112,000 MILES • 4 CYL • FWD • AUTOMATIC
MULTISTAGE
Have an 03 Camry with check engine light. My scan tool shows codes P0446 and P0441. I know these are emissions codes. Car will occasionally sputter upon inital startup, badly after fueling. Have changed plugs with factory iridiums, lightly sanded fuel filler tube sealing surface and replaced fuel cap with factory cap. Cleared codes, and yet they come back. I am hoping I am not about to change 300 dollar emissions cannister, but may have to. Am a Cat mechanic, so this repair will be not too terrible bad for me if necessary. Am not afraid of the check engine light, but the sputtering has my attention. Whay do you think?
Jul 11, 2010 at 10:39 AM
  • 31,937 POSTS
Hi there,
I would be checking the purge system as if you are getting raw fuel into the canister it will be destroyed, also did you check the fuel pressure and replace the fuel filter?
mark (mhpautos)
Jul 11, 2010 at 10:49 AM
