2003 Toyota Camry egr system
2003 TOYOTA CAMRY
68,000 MILES • 4 CYL • 2WD • AUTOMATIC
RMALBROUGH
vehicle has a p0401 egr insufficient flow code. has brand new toyota transducer, solenoid, egr valve, and map/boost sensor. egr ports are clean. egr tube has been removed and cleaned, and code is still returning.
Jan 13, 2009 at 12:33 PM
BMRFIXIT
  • 19,053 POSTS
Possible Causes
 Open or short in EGR gas temperature sensor circuit.
 Defective EGR gas temperature sensor.
 Vacuum hose disconnected or blocked.
 Open in vacuum switching valve (VSV) circuit for EGR.
 Defective EGR system.
 EGR valve stuck closed.
 Defective vacuum control valve.
 Defective ECM
very common is vacuum switching valve (VSV)
Jan 13, 2009 at 1:24 PM
REGO RONALD
where egr valve is located and how to clean it as my car vibrates
Jan 9, 2011 at 12:31 AM
