2003 Toyota Camry dashboard light replacement
WBERRY73
Electrical problem
2003 Toyota Camry 4 cyl Front Wheel Drive Automatic
On my 2003 Toyota Camry, the light which illuminates the dial on the ventilation/defroster function control is out. (Of three controls in the center of the dash, it is on the right.) All functions including the center A/C indicator light are working fine. How do I check or replace the bulb behind this dial? Thanks in advance for any help.
Apr 17, 2008 at 5:56 AM
DONBONE2003
were you able to replace the light bulb yourself? my problem is the thermostat dial. i want to take down the dashboard by myself but i cannot find some of the screws. toyota estimated the repair around Aussie$ 500 to $ 2,000 depending on the length of repair. i hope you already found the solution to your query.
https://images.2carpros.com/forum/automotive_pictures/185876_IMG_0028_3.jpg
May 2, 2008 at 1:40 PM
