I have just changed the brake pads and rotors on all four corners, used shims, and the stop squeal lube on back of pads. No promblems until brakes heat up, then while coming to a stop the squealing starts! Only squeaks when slowing below 10-15 mph, like at stop lights and stop signs etc... Can you help? Did I miss something? Also got all the parts directly from Toyota!
Feb 16, 2009 at 11:46 AM
