2003 Toyota Camry brake lights
90,000 MILES • 6 CYL • 2WD • AUTOMATIC
OLDTCHR
I just replaced the original battery, with a new battery from AutoZone. Same size, more CCA. Everythng runs fine EXCEPT that the brake lights are always on! IF the battery is hooked up the brake lights come on, all the time. What can I do?
Jun 13, 2010 at 9:05 AM
  • 75,988 POSTS
Adjust or replace the brake switch follow the brake pedal arm till it meets up with the brake support bracket its right here.
Jun 13, 2010 at 10:32 AM
