2003 Toyota Camry Battery warning light on
160,000 MILES • 6 CYL • 2WD • AUTOMATIC
ELWOODPDOWD
The battery warning light on the instrument panel has come on. Everything seems to working OK. No trouble starting the engine. What might be the problem?
Jul 21, 2010 at 8:09 PM
  • 75,988 POSTS
You have a problem in the charging system get the alternator tested-You have no problem right now-bcuz you are running on battery power once its gone-you gonna have a no crank and no start condition get it checked out
Mar 17, 2021 at 4:27 AM
