2003 Toyota Camry 90,000 tune-up
90,000 MILES • 4 CYL • 2WD • AUTOMATIC
KEVPHENIX
I would like to maintain the running of my car. I am looking to put it in for a 90,000 mile tune-up. What will be involved in this tune-up, and how much will it cost?
Thank you in advance for any information you can give me.
Feb 16, 2009 at 6:15 AM
GRSMNKY
  • 33 POSTS
a 90K service is every repair shops dream. Basically it involves doing everything that can be done to the car regarding maintenance. Plugs, wires, cap, rotor, pcv valve, brake inspection, tire rotation, replacement of belts, filters, and all fluids, and lets not forget the timing belt. Maybe even alignment. My advise is to simply check everything on the car and replace only that which is needed. A dealer 90K service can run you close to a grand!
Feb 16, 2009 at 8:26 AM
