2003 Toyota Camry
2003 TOYOTA CAMRY
139,000 MILES • 4 CYL • FWD • AUTOMATIC
ZIPPO747
Where is the adjustment and how do I release the tension from the serpertine belt tensionar to replace the belt? Must I have a special tool to complete this simple task? I am an OLD retired master mechanic and ASSumed this was a 5 minute job. haha!! Thanks ZIPPO74
Nov 10, 2010 at 7:23 AM
DOCFIXIT
  • 18,828 POSTS
See the 19mm bolt head in on tensioner? ratchet-19mm socket turn counterclock to release tension
Nov 10, 2010 at 7:32 AM
ZIPPO747
first attempt failed!! After backing off the 17mm bolt head more or less 1/2 inch,no belt tension was released. Is it necessary to remove the bolt completlely?
Nov 11, 2010 at 1:32 AM
DOCFIXIT
  • 18,828 POSTS
After looking at belt routing turn bolt clockwise. Not necessary to remove any bolts spring loaded
Nov 11, 2010 at 3:38 AM
