2003 Toyota Camry
70,000 MILES • 4 CYL • FWD • AUTOMATIC
IFEDI
I just had a new engine installed and on start-up, IGT 1 & IGT 4 doesn't work, only 2 & 3. Ignition coil has been switched & found to be ok. Ignition coil plug has been tested & there was current in them. Engine doesn't rev above 2000 rpm.
Jan 5, 2010 at 10:28 PM
RACEFAN966
  • 5,029 POSTS
Have you checked the injectors for those cylinders? they may be bad or not getting power.
Jan 7, 2010 at 2:53 AM
