2003 Toyota Camry
MISTERIAL
2003 Toyota Camry 4 cyl Automatic
I know nothing so can somone tell me how to replace the Iridium spark plugs? Where are the plugs located? I only see the a 16 valve cover under the hood. If their under this cover how to I remove the cover? I do not want to pay some one to do it if I can do it on my own.
Jun 22, 2009 at 6:18 AM
  • 31,937 POSTS
Hi there,
you need to remove the high tension leads, these are the 4 black plugs in the rocker cover, do this one at a time so there is no Chance to mix anything up, you will need a spark plug socketand extension bar with enough reach to access the plugs in the plug well, the plugs are a conventional thread, iridium plugs don't need to be gapped, they are a conventional R/H/ thread.
Mark (mhpautos)
Jun 22, 2009 at 9:44 PM
