Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Camry
Drivetrain
Wheel Bearing
Replace/Remove
2002 Toyota Camry Wheel bearings
2002 TOYOTA CAMRY
70,000 MILES • 4 CYL • FWD • AUTOMATIC
VAL.I
MEMBER
1 POST
Hi what I would to find out is how to replace the front wheel bearings as they are the drive
Thanks Val
Mar 14, 2008 at 8:40 AM
BLACKOP555
Experienced Mechanic
your best option right now is to take it in as the wheel bearing is pressed in and you need special equipment to change them.
Mar 14, 2008 at 11:13 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
