2002 Toyota Camry stripped wheel lugs
105,000 MILES • 4 CYL • FWD • AUTOMATIC
FABRIZIO32
Can stripped wheel lugs be retreaded? What is the thread spec for the lug nuts?
Feb 14, 2009 at 10:36 PM
MERLIN2021
  • 17,250 POSTS
Best to replace them. Just use a ball peen hammer and punch them out, use an air gun to install new ones.
Feb 14, 2009 at 10:42 PM
FABRIZIO32
[quote:9e013c347e="merlin2021"]Best to replace them. Just use a ball peen hammer and punch them out, use an air gun to install new ones.[/quote:9e013c347e]
What are the step by step instructions for removing the lug bolts in a 2002 Camry?
Feb 16, 2009 at 12:46 AM
MERLIN2021
  • 17,250 POSTS
First remove the tire, then the caliper, then the rotor, then use the hammer and drive the old lug out, insert new ugs and install a nut BACKWARDS with a large washer, and tighten to pull it into the hub, when it's seated against the hub, you are done...
Feb 17, 2009 at 3:59 AM
FABRIZIO32
[quote:9112668578="merlin2021"]First remove the tire, then the caliper, then the rotor, then use the hammer and drive the old lug out, insert new ugs and install a nut BACKWARDS with a large washer, and tighten to pull it into the hub, when it's seated against the hub, you are done...[/quote:9112668578]
Thanks Merlin2021 for the detailed procedure.
Feb 17, 2009 at 4:17 AM
